Has the CYA dissolved?
If you keep the FC between 2 and 3 ish for now, and the water is clear, you can swim.
It will; however, prolong the SLAM process.
One cup of CYA would only add about 10ppm. I suggest you add enough to get to about 30 CYA via sock method.
Then, adjust FC/SLAM FC accordingly.
But first, before you do that, have you added anything else that contained CYA? trichlor? dichlor? tabs? sticks?
How does the water look now?
Do you have well water or municipal water source?
Please let your sig post with each post. It keeps responders from having to scroll back up to your first post to find the info.
