I'm trying to pin down my fc usage and want to clean my light(1) and ladder. Do I need to drain my pool below the level of the light to remove the cover and clean it?
When I pulled mine to clean behind it I had the vac hose all set up and vacuuming to waste so when the light came out all the stuff that floated out behind it was sucked right out of the pool.The deck around it was all wet and I didn't feel like getting wet. I'll pull it out and clean it tomorrow. Around the outer edge was pretty gross so I am guessing there is algae in there that is eating my fc. My light is also in the deep end, hope I don't drop the screw
Thanks
