I am stumped. I’ve went through polyshere balls, sand, and now on glass media. (Bright line Brand). I still use the regular pump that came with the pool. I know it’s not the best.
The pool sat all winter, and I didn’t winterize it with nothing. So it was pretty green to start. I got it all cleared up and it’s like a blue color, but it won’t clear up for nothing. Stays cloudy. Been letting the filter run for 3-4 days straight.
I think I went to heavy on the chlorine and the stabilizer as my CYA is reading over 200, and my CHlorine on my kit only shows up to 10 with a dark yellow color, well mine is almost like a dark orange/brown after doing the drops. So it’s far beyond the actual 10ppm of chlorine. Would this be the reason the pool is staying cloudy?
The PH and Alkalinity is perfect. Right at the balanced levels.
My hardness is a little low as well at 100. So not sure if that has anything to do with anything. But I’ve ran claifier, phosphate, and everything to try and get all the dead algae out, and it never cleared.
So I’m currently draining half of the water and re filling with fresh water to try and balance out the chlorine and cya since there through the roof.
I can’t really vacuum the pool with this pool as there is no connections for it. So I can use floculant. It looks as most everything is broken up and dead anyways. It’s very small particles that are white on top of water. Not much. When you touch it with your hand it’s like they dissolve/disappear.
