Hello again, I am refilling my pool with tap water as we speak. It looks crystal clear. Hoping I can keep it that way.
Based on advice here, I have just ordered the TF100 test kit that is so highly recommended and should receive it in 5 days or so.
As I go to start my system up for the first time, assuming I get it running, should I be concerned about getting chemicals in here quickly. From what I've read, we can assume there is 0 CYA and 0 FC in city water. Do you feel it's important that I use pool math and start adding these immediately to prevent anything from taking hold?
Or, am I better to wait for the test kit to be certain, and then adjust for PH first as I have seen suggested on another post?
Thanks so much, Jeffery
