So I am about to install my SWG (Aqua rite pro T-15). I added about 500 lbs of salt to my pool....
Water is clear, and the chemistry appears right.
FC- 2.88
TC- 2.93
PH-7.9
CYA- 49 (Stabilizer??)
TA- 104
Cal- 190
Salt 3240 ppm
My question is that the CYA when using a SWG is supposed to be higher than when using chlorine (I think)...
So should I try to get the CYA up to the 70-80, or will the SWG take care of that once it is up and running?
If not how should I get it to increase....? I am assuming that CYA is stabilizer also...
Thanks
FC- 2.88
TC- 2.93
PH-7.9
TA- 104
Cal- 190
Salt 3240 ppm
Thanks
