Thread: what valve for quad de 100?
    Oct 2007
    Central Texas
    104
    these are the choices for valves - can anyone recommend one over the other? Multiport valves seems more common but also more problematic based on some of the related threads.
    Product Description
    261050 2 in. HiFlow valve, no plumbing
    261165 2 in. PVC Slide valve for D.E. filters & sand filters
    263034 2 in. ABS Slide valve
    270100 Adaptor kit (for no valve assembly)
    thanks.
    Light grey plaster, stone coping, 38K gallon Roman shaped pool with a shallow end beach, table and bar stools, deep end bench and waterfall (Intelliflo 4X160). Taylor K-2006, Pentair 320 chlorinator, Intelliflow VF, Quad DE 100. 4 ColorLogics, 3 skimmers, 14 wall returns, 13 floor returns, TurboTwister slide, autofill and miles of pvc.
    Re: what valve for quad de 100?
    With the Quad DE 100 there is no need to backwash, but if you are planning to backwash the filter it is really nice to have a multi-port valve with a rinse setting. DE filters tend to release the last bits of DE for a very long time. The rinse step prevents that DE from getting back into the pool.
    Mar 2008
    Palm Springs, CA.
    49
    Jason, or anyone else, in your opinion, which of the valves would you recommend? Would the 261165 Hi-flow slide valve be just fine? Or is there a suffecient reason to go with the 261050 Hi-flow multi port valve.
    Thanks
    Greg
    41k pool, Pentair Intelliflo VS main pump, Jandy stealth 3hp water feature pump, Jandy stealth 3hp spa pump, Jandy LX 400 heater, Pentair 4000 DE filter, Jandy Aqualink RS controls, Jandy aquapure chlorine generator, 2 Pentair pool SAm lights, 1 Pentair SAl spa light. 4 Jandy deck jets, 1 Jandy sheer decent, Rico rock water fall.
    Oct 2007
    Central Texas
    104
    The manual uses the term backwash but that really means remove the cartridges, clean them and recharge with another 10 pounds of DE. So you don't actually ever "backwash" a Quad DE; is this correct?
    So why do they offer a multiport valve? Do I need it for anything?
    You can backwash the Quad D.E., provided you plumb it in correctly. However, I installed mine about two weeks ago without any backwash valve at all. I used the #270100 kit that allows you to hook it up like a cartridge filter. When you do this, you have to remove the cartridges and hose them off. I did this for two reasons: 1 - My equipment is in a poolhouse closet and space was tight. 2 - I up sized to the Quad D.E. 80, so I should have some decent intervals between cleanings and I like the idea of getting ALL the gunk out of the filter. Yeah, you need to replace the D.E., but a 25lb box ($19) is good for three recharges.
    I cleaned the filter for the first time a few days ago, just to get all the new pool crude out. This is my first pool and the manual is not exactly the best, but I was able to figure it out without too much effort. (Oddly enough, they make no mention of the fact that you have to replace the D.E. ofter cleaning the cartridges.) It took about 45 minutes. I think I could do it in under 30 minutes next time, maybe even 15 minutes if I get everything dialed in just right and have all the tools and supplies at the ready.
    So far, no regrets going sans backwash valve.
    Ponz
    Cleveland, Ohio
    20 x 46 Vinyl (self-built)
    Pentair Intelliflo VF pump : Pentair Quad D.E. 80 filter : Pentair IC-40 SWG : Raypak 335k N.G. heater
    Diving board : Slide : 4 Jandy Deck Jets : Automatic Cover
