Hi Slythic,
Im glad my post was helpful.
No, the SWG does not necessarily need to be on whenever the pump is running. How long it needs to be on depends on how much chlorine you need to make in a day in order to maintain your FC. Determing that is pretty much a matter of trial and error and testing over the course of a few days.
Regarding the intermatic or external timers -
You cannot put an external timer on the Pentair VS pump (not sure about others) and maintain all of the automation features of the Pentair VS pump. I will explain more about that at the bottom of this post. You run power from the breaker directly to the pump.
The control module on top of the VS pump has timer functions built in, and a date function, so an external timer isn't needed anyway. I use those built in timers to set the start and stop times of the pump. You can program however many start and stop times you want to. Once I have my run times and speeds programmed for whatever I want them to be, just push the start button, and from there, the control module takes over. It's a beautiful thing! The Pump being off overnight is just a long pause betwen the last stop time and the next start one.
If the power goes off, Im certain I will have to go out and do something, but Ive not lost power since my pool was built, so I dont know exactly what I might have to do. I think there is a battery backup in the pump control module to keep the clock running and prevent the program from reverting to default. I would have to refer to the manual to be sure, but its late!
I use a Intermatic Timer set to turn the power to the SWG off when I am just skimming on low speed and dont need to make chlorine.
I have my timer to the SWG set to turn on 10 minutes AFTER the pump start time, and turn off 10 minutes BEFORE the pump stop time. This ensures there is water always running through the SWG cell whenever it is powered up.
It is not a good idea to have the SWG powered up for a long period of time without water flow through it. For one thing, its just wear and tear on the when its not necessary. Nothing wrong with trying to extend the life of it as long as possible, expecially considering the cost of a new one.
Now for the most important reason .... There is a flow switch built in to the SWG. Now here is something important to understand. > If the flow switch senses that there is not enough water flow through the cell, a red light alarm for No FLOW will light up, and the cell should cease to attempt to make Chlorine. But, WHAT IF?
What IF the Flow Switch on the SWG fails and there is no flow of water to carry the chlorine away? What will happen? Well what happens is the SWG will still continue to make chlorine. The failed flow switch tricks it into thinking everything is OK. Chlorine is a gas and that gas getting trapped in the cell and plumbing could be a potentially dangerous situation, [Edit - during the electrolysis process of making chlorine, hydrogen is produced and hydrogen can be explosive]. It's been known on occasion for an explostion to happen because of continous power to a cell, with no or low flow because of a failed flow switch.
A timer is cheap insurance against such an event.
Now about my comment earlier of not using an external timer with the VS Pump;
The control module on top of the pump needs constant power so the clock and internal timers continue to operate and control running the program. Somehow, some power is drawn from one leg of the input power to satisfy the control module and keep the thing going.
If power is removed from the pump by the external timer, the pump basically is forced into a hard power reset. A power reset puts the pump into OFF mode and will not automatically start back up when the external timer re-applies power to it.
You would have to physically go out to the pump and push the ON button to resume operation of the pump and your program, thus eliminating the auto function of the VS Pump. I found this out the hard way by spending 300 dollars on a timer that I didnt need.
Being in Florida, you may never need it, but the Pentair VS also has a built in Freeze Protection. Just thought I would throw that in there to boot!
If you were using a 2 speed pump then an external timer for the pump would be necessary to perform a simular type of run time program, but without the added feature of controlling the RPMs
Im afraid I dont know anything about repairing plaster, but maybe someone else will chime in on that.
Also, if you have a light in the pool, consider putting a timer on that too. Its worth the convenience of not having to turn it on and off every night.
I hope this helps. Feel free to continue to ask questions as they come up and I will try to answer them as accurately as I can.
