Thread: Backwash setup
    DaveNJ's Avatar
    Toms River, NJ
    520
    Backwash setup
    I got around to finishing my backwash setup. The pop up is for downspouts, the wifes find. Seems to work pretty well.[img][/img]
    [img][/img]
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Arizona
    925
    That's a popup that is connected to your downspouts?
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    From_Arizona's Avatar
    Glendale, AZ
    212
    That's pretty cool.... most areas of AZ restrict you from backwashing or draining to the street. We use backwash pits or wash out areas within the yard.
    1980's Shasta built 30,000 gal inground diving pool. Pebble-tec interior. Pentair DE Filter. In ground pop-ups. Hayward Navigator sweeper.
    DaveNJ's Avatar
    Toms River, NJ
    520
    Buggsw
    Its connected to the filter only by about a 150ft of 2" pipe.
    Mar 2007
    Morris, IL
    477
    I want to dig in a bog garden, dig a big hole, put down some plastic, fill some of it with pea gravel, place a pipe in there, and fill the rest with black dirt and peat moss and fertilizer. Then I could just backwash into the pipe, and it would also provide water for the bog plants.
    Right now though, I just have a quick connect coupling on the pump, and another on the hose, and when I back wash I just roll it out the back fence and blast it out into the alley.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
