ok I am currently in the last stages of pool construction and have posted the construction thread in 'under construction' forum (with pics!)
I am in the middle of wiring. I have a suntouch automation system, intellifo VS and an Aquarite 40k SWG. currently I have the pump on its own 20A 2pole GFCI breaker and attached to the suntouch via comm cable, which was provided with the pump. I have a second 20A 2 pole GFCI breaker run to the suntouch and pigtailed to the suntouch transformer and then run over to the SWG, basically suntouch and SWG on same breaker.
first question, (warning i am probably missing something simple) i ran 12-3 (red, black, white and ground) to all of the above. none of the pool equipment have connections for the neutral/white wire, but obviously the breaker does. where do i attach the neutral in the suntouch, pump and SWG?
second question, the aquarite manual indicates to use any 4 wire comm cable to connect to the suntouch system, where does this connect in the suntouch? do i need another relay?
third question, where do i attach bonding wire to the suntouch? it appears there is a slot on the grounding bar.
thanks
thanks
