I don't know what I'm doing with this new version of website so please forgive me if this posts twice.
2nd season before I found u guys I hired a guy to install my pentaire pump and sand dollar filter. I never noticed u til I was ready to make some modifications that its backwards. My intake and out take they are backward the intake should be the one way below waterline with the grey cover with holes and the out should be near water line. At least now I understand why I had to keep my pool filled so high to avoid that sucking sound because not enough water was getting I to pump.
How can this be fixed? I hired someone because I'm disabled Andy husband does t touch pool he's a computer guy. I wanted to make following mods to my pool this year
1. Install my Hayward (not of mouth) through the wall skimmer bought last season
2 use my auto vac I'm told can not be used as I do my reg vac just plug it in the hole must have a skimmer
3. PVC waterfall once we start staying at 100+ pool stays above 90degrees. Live in az
I imagine before I can do any of this I must find out how to fix the reversed plumb situation. FYI can not get guy who did it to fix he was suppose to install the thru wall skimmer as well but he took money and moved to Colorado so that's out. Learned lesson dont pay on advance. ( got it back filed fraud thru bank). Anyway how do I fix my situation? Also if I put it right the gray thing is stuck on there like glue how will I vac pool if can't do what I've been doing just sticking the vac In the whole for intake here's. no ball Installed not a major concern I have no trees nothing larger then a bee gets in my pool.
Advise please as always tha I you.
