Results 1 to 7 of 7
Thread: Pump Problem
    May 2008
    florida
    112
    Pump Problem
    My pool was working fine yestarday and today it didn't turn on. At first I thought that the electric co had it stopped for a while. I went out again because it didn't come on and heard a low humming sound. Turned it off, cleaned the filter which wasn't dirty. It hums then stops. Does that mean it is dead? What do I do?
    Re: Pump Problem
    I'm by no means a pump expert, but is it possible that the impeller is blocked and it's the thermal overload kicking the motor off?
    May 2008
    florida
    112
    Re: Pump Problem
    What is an impeller and where is it on the pump?
    Re: Pump Problem
    It's inside. If you look into your pump strainer with the basket removed, the hole that goes into the pump leads directly to the impeller chamber. You could make sure the power is off (pump un-plugged), take out the basket and stick your finger in the chamber to see if you can feel any obstruction or if you can turn the impeller.
    Or better yet wait until an expert chimes in
    Jun 2007
    SF Bay Area
    441
    Re: Pump Problem
    dd50,
    When we talk about a filter pump, or any pump really, it is comprised of two parts. The first part is truly a pump, and the impeller is the part that spins and physically moves the water. The second part is an electrical motor, and there is a rotating shaft on the electrical motor which attaches to the pump and spins the impeller.
    If the problem is not a blocked impeller, then the problem may lie with the electrical motor. Pool motors can fail in several different ways, in no particular order or completeness:
    1. Failed start or run capacitor.
    2. Failed or dirty motor contacts in the motor
    3. Failed motor bearings.
    Here is a YouTube video on how to replace a motor capacitor. CAUTION: Don't do this unless you know how to work safely around electricity.
    [youtube:20i0j0yp]ZEIv5ClLqXg[/youtube:20i0j0yp]
    Sometimes Cause #2 above can be temporarily "solved" by whacking the side of the motor (not hard enough to dent the motor) with a stick.
    http://www.ehow.com/how_2214569_repair-pool-pump.html
    http://www.troubleshooters.com/pool/pump/index.htm
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    May 2008
    florida
    112
    Re: Pump Problem
    Thanks, think I will call Pool Doctor after I check if it is the impeller. I will see if it will turn. Don't like to play with anything electric, and electric and water I'm not that brave. I think I replaced the pump about 2 years ago, but can't find the receipt. They gave me an estimate of $345 if it is the pump and they said that is what it sounds like. It is 1 1/2 hp.
    May 2008
    florida
    112
    Re: Pump Problem
    Pool Doctor put in a new one for $345. They said pumps only last about 3 - 5 years. Don't know if that is true but it seems I have been buying them about every 3 - 5 years. Mine is run all year long for 8 hours a day.
