I had been maintaining a 3 step bromine system for my spa since the Summer and I am running into two problems:
1) After shocking I cannot get the bromine level down for days (5+). I think the simple answer is that there is not enough for the bromine to kill off so I should shock less frequently despite everything online saying weekly. Once bromine levels are normal and we go in the tub the bromine levels drop really quickly with use, meaning that I do need to be ready to shock it after uses, so getting this right is very important. The tab floater, sometimes alleviates this and keeps the bromine levels good between uses, but...
2) I think the minor chlorine in the bromine tabs might be irritating my skin. I discovered this because when the bromine levels were too high after shocking I would have to take out the floater to let the levels drop as quickly as possible and I found less or no irritation when the floater had been out for some time (assuming that means the active chorine levels dropped by this point with the floater out).
The best conclusion I can come up with is to move to a 2 step program and eliminate the tabs b/c they are keeping the bromine too high after shocking and possibly irritating me. If I do this, what is the best way to think about using the shock (Leisure Time Renew) to maintain a good bromine level? Trial and error with how many scoops and how often despite what instructions say? Is there a third option I should explore?
If I stick to a 2 step system...any product recommendations? I am currently using Leisure Time Sodium Brom to build the reserve and then Renew to shock/replenish the bromine.
Tub is around 400 gallons with an ozonator, which is probably contributing to the bromine level problem. Ph always stays around 7.2-7.4. Nothing else notable to mention.
Thanks!
Thanks!
