Thread: Can't get rid of that hint of green............
    Kathyonthefarm's Avatar
    Jun 2008
    Chatham, Ohio
    12
    Have been living with just a hint of green for just a couple weeks...........finally got my Chlorine up to shock
    FC 30.this is the second day for that value
    TA 150
    Ca 200
    PH 7.8
    CYA..45
    34,000 vinyl in ground
    I am getting anxious................sand filter is running 24/7........very full sun all day.
    How long should I give the chlorine to blue the water before moving to poly quats?
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Can't get rid of that hint of green............
    You should check your FC levels in the morning before the sun gets on the pool and adjust back up to shock levels. You need to keep this up until there is no FC loss during the night. This may mean checking your FC levels a few times a day if you are able to. Lots of brushing and back washing is needed as well. Once you have no FC drop during the night you can gradually let it drop back to normal FC levels for your pool Getting algae under control takes lots of POP (pool owners patience) .
    Good Luck !
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    ktdave's Avatar
    Katy, TX
    888
    Kathy,
    Tizme has given good advice. This article in the pool school will be very informative http://www.troublefreepool.com/categ...efeating_algae
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Jun 2008
    Chatham, Ohio
    12
    Thanks for the replies...........going to stick with the pop and check the FC...........
