Thread: Need advice on Vermiculite Bottom (Pictures)
    Nod's Avatar
    Jun 2008
    Nashville, NC
    69
    My PB was out today putting in the vermiculite bottom to my pool. They were very quick and took approx. 3 hours to complete a 16x32 8' deep pool. Anyhow, after looking at it, I see alot of trowel marks and it doesn't look that smooth. I am incorrect in thinking that the bottom should be smooth (like a home depot concrete floor), or is it normal to see these trowel marks?
    Any advice is appreciated!
    Thanks!
    http://picasaweb.google.com/terryisnot/ ... 1475364290
    http://picasaweb.google.com/terryisnot/ ... 1463774450
    (Couldn't attach the pictures to the post)
    Nod
    16x32 IG, polymer panel Vinyl Pool w/approx 21k gallons of H20
    1 HP Hayward Pump & 300lb Sand Filter ~ Polaris 280 Pool cleaner
    ~~Nashville, NC~~
    Aug 2007
    Powhatan VA
    50
    Re: Need advice on Vermiculite Bottom (Pictures)
    Welcome Nod !
    I finished a similar pool in my backyard this spring with a vermiculite/cement bottom. It's almost impossible to get it smooth like a concrete floor. As Duraleigh so eloquently put it - 'You think you have it perfect, and when the lights come on it looks like the surface of the moon.' Your install looks quite nice so far, with nice, crisp corners and angles.
    That looks like a light niche in the deep end - I would expect to see some imperfections on the floor near the light when it's on at night. It's just the nature of this type of bottom. The bottom of my pool is not as smooth as yours and I only notice it at night, but it's still no big deal.
    The orange you see is the wonderful Powhatan County clay that washed in during a heavy rain.
    Now, go read the stickies for BBB so you are ready when the water goes in ! Looks like you are going to have a great pool.
    20x40 IG Vinyl
    33k Gallons
    Triton TR-100 Sand Filter
    Pentair WFDS-6
    Nod's Avatar
    Jun 2008
    Nashville, NC
    69
    Thanks for the info!
    The PB was out yesterday and they smoothed out the bottom, dropped the liner in, filled the pool and backfilled. My soil is mainly a sandy mixture, and it was used for the backfill. The only issue I have now is that the PB wants to put the concrete over the sand backfill. There are no sono tubes, just the concrete supports on the pool braces that came with the pool kit. When I asked the concrete guy if I should be concerned of the ground settling, he said no because it was sandy soil and wouldn't settle much more.
    So knowing that, should I be concerned. I thought about renting one of those plate compactors and wetting/compacting the sand. Any advice on that?
    Nod
    ~~Nashville, NC~~
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Just went through that myself. With a plate tamper, water and some patience. We watered a little tapped alot watered a little tapped alot. I did mine over the course of 2 weeks and had my concrete done on Tuesday. I didn't want to take any chances! Good Luck, with your new pool. It's looking good.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Aug 2007
    Powhatan VA
    50
    Something I learned here a couple of weeks ago: If the builder puts rebar in the concrete make sure it is connected to the pool bonding wire(s). 8)
    20x40 IG Vinyl
    33k Gallons
    Pentair WFDS-6
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    546
    Nod, I will tell you what a friend of mine said to me when I complained about the pool bottom. You'll just have to let it go! When my floor was poured (it's the vermiculite as well...looked just like yours) it looked pretty good as far as I could tell. I guess the PB saw something I didn't and had his guys re-sweep, etc. Well, the first night I have the lights on - SHOE PRINTS! I tried to take pictures of it last night for you, but they didn't do justice. I just take another sip of my favorite adult beverage and look away! Night time is going to be the only time you see anything. Besides, you'll be too busy enjoying the pool to worry about it...promise!
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Letro Legend II cleaner; Emerson 1HP pump; Pentair Boost-Rite booster pump
    Bioguard Mineral Springs SWG
    2 skimmers
