- Jun 20, 2008
- 7
I have a trainer pool. This is my first season with it. I am doing decent with the chemical balance and all, but the dust and algae debris on the bottom of the pool is killing me. The algae will start to form if I forget to do my weekly dose of algaecide and once I add it it kills it and it needs to be vacuumed out. My vacuum is the type that you connect a water hose on, and put a bag on the out port to collect the stuff that it vacs out, but the bag allows everything that is small enough to go right back out into the pool. So I am looking at getting a seal suction vacuum. But, what i am stuck on is what kind can I get that will work with the little pump/filter combo that came with the pool. If I get a vac head and hose, with proper adapter to fit the hose into the overflow hole going to the pump/filter would this work? or would I just end up killing my pump/filter needing to replace it? I am doing all this on a budget so i cant spent hundreds of dollars on a new filtration system just so i can use a vac, but I need to figure out how I can get this sediment off the bottom of my pool.
Thanks
Mike
Thanks
Mike
