Hi All, Hoping you can give me some quick advice. I am closing my pool this Friday and am about to do the final shock. I have three questions:
1. I usually have a solar cover on the pool. Should I remove the solar cover before I shock it? I'm asking because it usually stays at shock level extra long with the solar cover.
2. Is Leslies Algae Control the same as Polyquat? Want to know whether I can use what I have or if I should go and buy some Polyquat. Leslies Algae Control says to use 10-16oz per 10,000 gals. Is that sufficient for closing?
3. I have solar roller coverstick from Solar Factory (http://www.solarfactory.com). How do you guys usually store this for the winter? Is it fine if it is rolled up, covered and stored outside?
Thanks in advance guys.
