Here is a little more info. Pool builder came yesterday to remove a stain off of tanning shelf. He used a bucket of Jacks Magic and 2 gallons of acid and it wrecked my levels.
Hey neighbor. If you got that TA number from your 2006 kit and trust it, then bring it up first. You really do need to get some chlorine in also. Don't really need a long turnover time between the two. Just don't start a slam yet if you need to. That will keep your FC lower so it won't skew the pH test. I would shoot for about 70 or so on TA. Then test your pH again and bring it up to about 7.4 or so. Most pools in this area like TA around that. All pools are a little different so you will need to find it's sweet spot and your pH should then become stable.
