Hello, glad I found this site. Just installed a pool her in New York last month. I installed end of summer to let the ground settle before putting a deck in the spring. It is a 12 x 24 oval semi inground with a saltwater (vertical to the return) generator and a 1.5 pump with a cartridge filter. I would like to winterize the pool this weekend, but I am lost as on where to begin. My return hose goes into the saltwater generator, which then goes into the aqua luminator on the return. I was give a black "winter plug" for the aqua luminator when I bought the pool. How do I take this off? the aqua laminator instructions do not say how to "plug it". Do I take off everything for the winter, including the saltwater generator? I have a plate to put on the skimmer which is pretty straight forward. Do I need to drain the water to below the return to get this plug into the aqua luminator? does it go in from inside the pool or outside the pool? Any help would be greatly appreciate, Thanks
