Assuming an average depth of 48", 8" will lower the CYA by 16% ... from say 300ppm down to 250ppm ... a start, but a long way to go.
Ok, I think my plan will be to drain 8 in each month, hope for rain. off tablets and shock, use polyquat 60 until I can get the cya down below 100. Am I on the right track now?jblizze said:Every time you drain it 8" you will lower the CYA by 16% (assuming average depth is 48" and you are not adding any more).
So the CYA will progress like this:
300 > 250 > 208 > 174 > 145 > 121 > 100 > 84 > 70 > 58 > 48
So assuming you are starting at 300ppm and your average depth is 48", you will have to drain 8" 10 times to get the CYA in range.
Given the high amount of sun, you may be able to stop around 70ppm, but you certainly want to get below 100ppm.
techguy said:Yes, if you drain 8 inches of water and replace it with fresh fill (or rain), your CYA will go down.
Were you planning on leaving the pool down 8 inches until rain fills it? Are you closing the pool for the season?
Having taken the above comment into consideration, I drained the pool 8 inches ( 19x33x 4.5ft), and the catch basin for negative edge holds 760 gal(using the pool calculator) it was empty. Refilled with fresh water. Should I run pump over night to circulate?? Will add weekly dose of polyquat. Keep FC 5. Is pool safe to swim. Water is clear now. If no rain, drain 8 in next month?Donldson said:From chem geek's personal experiences, as mentioned here:
My take from that is he believes that he could potentially have had an FC of 3 with perhaps 250 CYA and prevent algae. I am thinking that since dkbrat's pool is currently clear it is probably low on nutrients, and thus with the polyquat can probably run around 10 FC with 360 CYA and manage to get by until a source of water can be obtained.chem geek said:I can tell you from personal experience that Polyquat will not completely prevent algae growth, but it will slow it down. In my own pool 9 years ago, I was using Polyquat but only dosing every other week (one is supposed to dose every week because it breaks down from chlorine and can also get filtered out if water is dirty since it is a weak clarifier) and had algae start to grow faster than chlorine could kill it with 3 ppm FC and 150 ppm CYA. Had I used the Polyquat weekly, then I speculate I could have had the CYA get to perhaps 250 ppm but I don't believe that Polyquat alone would prevent algae growth when algae nutrient levels (phosphates, nitrates) are high.
I normally wouldn't suggest it, and it is uncharted territory no question. In my opinion it is the least bad option, since a 30 FC level would hinder pH readings and burn through reagents very quickly. This plan will allow some leeway to be able to get accurate pH readings. I do like your idea, jblizzle, of maintaining the FC a bit above 10 and letting it drop occasionally to get a pH reading.
Donldson said:For a CYA of 300, roughly 120 ppm.
I'm not sure how the catch basin you mentioned works in your pool relating to draining but if the 760 gallons you calculated it holds is in addition to the amount you're draining from inside the pool you'll be able to get to a more manageable CYA level even quicker.
