I'm new to this Forumn and I have read several threads about the pool frog and how people don't like it.
But, I have a question. Has anyone refilled the chlorine BacPacs with 1" tabs? If you have what did you use to seal the top off with after refilling? I assume you drilled a approx 11/8" hole at the top to add the tabs.
The Bacpac is supposed to work by keeping an air pocket which I guess only gets a certain amount of tabs wet which keeps them from dissolving so quickly.
