I only have one pressure gauge on the filter which is running consistently 3psi. When I did some research to see if this was a good pressure, find that folks have a gauge on the pump, too. I don't. Looked at the diagram for parts and there is nothing about a place for a gauge. There is a hole in the pump for water release, 1/4" NPT, which is the same size as the regular replacement pressure gauge I get for the filter.
Pump: Premier Pump 475V 10 1 HP (455AB for parts)
http://www.poolcenter.com/parts_pumps_premier.htm
I know brass pump, but just cleaned and put a new gasket on it the 4th of July, it is a perfect piece of machinery - a bit noisy, but perfect.
Filter: Mytilus MA-90C S/N 09921
http://www.poolcenter.com/parts_filters_pacfab_mytilus_507090C_.htm
What is a gal to do - have been using with only filter gauge for over 5 years, with no issues in maintenance or treatment, so do I need it? Any thoughts on this matter? Not a problem in my book, but curious as it reads that maybe I should.
