Gentlemen: And Ladies, sorry.
I'm trying to figure out if I can plumb from the pressure side through a valve to a 1" pressure return line currently operated by a PB-4 3/4hp booster.
I want to see if my Pentair Intelliflo 011018 VS pump can pump enough water to run a "The Pool Cleaner" pressure side cleaner that needs 11-15 psi to operate/22-25 gpm. I just want PG&E and .36kwh power out of my life. The pressure line around the filter is all 2".
Thanks, Luther (ignorant pool owner)
