I am approaching close to one full week with my first pool ever. So far I have been using the BBB method and so far, everything has been great. My question is this, what should I be doing to test my daily chlorine use? Should I be using the test in the blue box (taylor) for the daily and add chlorine based on that? (If it reads 3, add enough bleach to raise it by 2ppm). I have the tf100 test kit by the way. I ask because I'm assuming I'll run out of stuff quick if i'm doing the FAS-DPD chlorine test daily (or twice daily, as I was doing at first).
