Thread: Diving Jig Distance
    Diving Jig Distance
    Hello-
    I just had a 20x48 pool installed and I'm waiting for the rain to stop so we can pour the concrete deck. I'm concerned about the proper distance to mount the diving board jig because there is a discrepancy between my pool builder and Interfab. The pool builder states 27 inches from front Jig bolt and Interfab states 13 inches. Below are the technical details.
    20x48 pool
    4 ft. slope on diving end
    6 ft. diving well
    14 ft slope from deep to shallow
    This is a typical vinyl liner pool and I'd like to know what distance others have set the diving jig for the Durobeam/La Mesa base. Any help greatly appreciated.
    Thanks
    Terry
    lartay
    Dec 2007
    Central New York
    504
    Re: Diving Jig Distance
    What is the diving board length? I would say you are talking about a 6 foot board.
    Where do you see 13 inches in the manual?
    http://www.inter-fab.com/files/durobeam_install.pdf
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Dec 2007
    Central New York
    504
    Here is another site to find out what your pool type is.
    http://www.srsmith.com/_posted_resou...stallation.pdf
    If you figure your pool type out, then you can find on the chart the distance from the water to the forward jig bolts.
    Hotrod30
    Pentair VF3050 pump
    Hotrod30
    I called Interfab and provided them the measurements for my pool and they stated it was 13 inches because it's a vinyl lined pool and the walls have a 4 ft. slope in deep end. They indicated there manual is for Gunite pools only and you must call for Vinyl dimensions.
    Thanks
    Terry
    lartay
