Bottom line: Added 8 gal 10% hypo to <1 FC pool, now testing shows I have 61 FC? Pool calculator said 8 gal would add 30 FC.
Tested after 24 hours running the pump. I added my pool water to the 10mL line, added bottled water to the 44 mL line for dilution, 2 powder scoops, and it took 28 reagent drops to turn the pink clear. 28*0.5*4.4 = 61.6 FC if I did my math right.
Background:
During July my SWG was having trouble keeping FC up and I noticed green algae started to form on the rock features (water was clear though). Had my SWG set to 100% and pump running 12 hours/day. My numbers at sunset were:
<0.5 FC
0 CC
75 CYA
7.4 PH
3500 salt
300 CH
90 TA
100 Phos
Air temp: 105* avg high
According to the SWG calculator on this site, my system should generate 7.2 FC per 24 hours, and since I ensured my SWG was clean, visibly producing chlorine gas, no error lights, water perfectly balanced, etc, my last resort was to shock the pool because something must be eating all my chlorine. Can't really do the OCLT because I have to run my SWG and pump and night due to peak electricity costs and don't want to go a night without adding chlorine since I'm falling behind. Hope this fixes it because I am out of ideas, but I don't understand the 61 FC reading after shocking. I used the pool size calculator to determine my pool size, and every chemical addition I've done in the past has resulted in accurate results for my calculated size.
Background:
<0.5 FC
0 CC
75 CYA
7.4 PH
3500 salt
300 CH
90 TA
100 Phos
