seanm said:
Mark,
Since you are a Pentair installer, have you installed a ScreenLogic system on an ATT Uverse router? I do appreciate the info you shared, but that was my original question.
Just to clarify I
do not work for, nor do I receive any compensation from Pentair or any of the other BIG 3 mentioned. However, since I not only install equipment I "actually" have hands on use of the stuff 6 days a week and see first hand how certain equipment and systems work and don't work efficiently. And
in my opinion Pentair crushes their competitors without a doubt (but that's another story).
Now with that said the short answer to your OP which I apologize for not addressing it properly in the first place is
NO! :lol: sorry
Now I have read your OP again and you don't mention if you are on a PC or MAC.
If you're on a MAC, buy a PC :lol: oh yeah I'm as anti Apple as they get, but since so many [s:10dr6jio]sheep[/s:10dr6jio] people
use Apple products I unfortunately have to deal with them on occasion being that I do network multimedia storage installations also. I have done a few where U-Verse is the ISP so in one way or another this experience may help you, who knows :?
U-Verse can be a PITA to set up network gear, it also can be easy as plug and play, I've experienced both when installing additional switches or routers and suggest you do so from your homes PRIMARY computer (the one AT&T used to set-up the equipment on initially). You shouldn't have to do the following but if you have to then you can log into the router from there if you need to assign a static ip address. As stated above the ip address for your log in is provided by Pentairs Servers not your homes, but I think you're inquiring if there has been any issues with basic connection in general.
I have found to get around any havoc in general with all ISP Hardware is to install an additional wireless router I use similar to this type by
ASUS and have never had any issues with some pretty complex installations (ymmv). NO I'm not employed or compensated by ASUS I just know their products work for my needs.
You shouldn't have any trouble if you went the additional wireless router route which adds a whole bunch of other capabilities in the process but that is up to you.
EDIT*Tomorrow morning I'll hook the protocol up to a U-Verse box and see what happens and post back the results for you.
Good luck in the mean time.
EDIT: Removed irrelevant information and added U-Verse test
