G
Guest
Re: HELP PLEASE!!
PH is now 7.5. going back to trying to hold 12 as much as possible.
duraleigh said:I just scanned your thread and perhaps have an answer that makes sense......ammonia.
Assuming you had CYA when you closed last year, there is an over the winter process that CAN (not always) convert CYA to ammonia.
The result will be voracious consumption of chlorine until the ammonia is burnt out.
At that point, the chlorine consumption reduces rather dramatically but you still may need to continue the shock process to get the pool clear.
That seems to sound like your situation but, even if it is something else entirely, the answer remains the same.....continue to shock the pool until it is crystal clear.
So keep your FC at shock level, brush, vacuum as often as you can.......keep an eye on your filter psi and your pool will clear.......you may need some patience
mkdsk102 said:I would have drained it, cleaned it then refilled it. :lol:
jblizzle said:mkdsk102 said:I would have drained it, cleaned it then refilled it. :lol:
Did you factor in the cost of a new liner than would likely be required if you drain a non-temporary AG pool?
Brushpup said:Well, we do know that with that CC level, there is a lot of shocking yet to be done. Hang in there man and it will come around. Six hours is fast for CYA to dissolve...are you sure it didn't escape the bag somehow?
Burnsy said:Edit: I need to order more FC test reagents.
