I've maintained my pool for 6 years by just going to the pool store and having them test. I used 3" chlorine tabs up until this year. I know that's a cardinal sin on here. 3 years ago, I completely drained and re-plastered the pool. So, I've had maybe 2 full years of using the tabs in this batch of water.
This spring, I finally decided to switch to the TFP method and a SWG because of the CYA battle over the past several years. (Also a tree came down on all of my pool equipment, so I had an excuse to redo all of my equipment). I had drained the pool about 1/4 of the way down over the winter, way more than I needed to in hopes of putting fresh water in to lower the CYA.
With that backstory, I just opened the pool about a week ago and got some brief instruction from the pool company that installed my new SWG (and all my new equipment - filter, pump, propane heater) on how to be a SWG pool owner. I finally got a TF-PRO SWG Test kit and am enjoying doing the testing. However, out of curiosity, I also took a sample to the pool store to see how their results compared to mine.
Here is a table with my test vs the pool store:
So, my CYA (when I test it is below what is recommended for my SWG pool, while the pool store says its over 125. I don't know if I'm just trying too hard to see that black dot so I keep adding drops. I've long expected that my CYA is really high, which is why I switched to a SWG anyway. Also, my pH seems fairly different.
Maybe I'm just having a hard time divorcing myself from the pool store tests, but how can they be so different? (especially the CYA). I used extreme care to do the tests carefully and following the instructions. I tested using my TF-Pro both yesterday and today and got very similar results.
My pool is crystal clear. Using the pool store tests and their recommendations, I've never had any issues really. So, now following the TFP method (which I very much appreciate) It seems I should lower my alkalinity, lower my pH, and increase my calcium. Yet the pool store recommended none of that. The values appear out of their recommended ranges, but they verbally just said "everything is fine".
I'm just a little frustrated not knowing who to trust or what to do. I've read posts from all of you experts, and I want to go all in on TFP, but don't understand especially the large discrepancy in CYA.
Also, I know I clearly need to shock and boost my SWG chlorine output. How do I shock now that I have a SWG?
My Test (TF-PRO) | Pool Store Test | |
Free Chlorine | 2.5 ppm | 0.5 |
Combined Chlorine | 0.5 ppm | |
Total Chlorine (is this the same as CC?) | 1.0 ppm | |
pH | 7.9 | 7.4 |
Total Alkalinity | 130 ppm | 180 ppm |
Salinity | 3500 ppm | 3500 ppm |
CYA | 55 ppm | 125 ppm |
Total Hardness (Calcium Hardness) | 300 ppm | 200 ppm |
