Re: 1st Time Poster - Day 8 . SHOCKED + CRITTER!
Hello forum members. So far so good, and again, thanks for the help. I have questions at the bottom.
My last full test results from day 6 (two days ago) were:
OTO - 0
pH - 7.4
FC - 0
CC - 1
TC - 1
TA - 60
CH - 340
CYA - 55
TEMP - 74
Other items. Pressure gage replaced. I had to clean the filters again, just to know what the baseline for clean was, and it is 11 PSI.
I decide to shock starting yesterday so I vaccum to waste again, fill, (we have had a lot of rain in the last 24 hours), clean the filters, and brush everything. I see no yellow.
I start shock process in the afternoon at 2:20 PM. I start with 6 gallons of 8.25. This raises FC to 15, not enough,
I put in 4 more at 4PM, test at 5PM and I'm up to 28. Good to go.
Test at 7:15, FC is 19, and I'm guessing I'm about 2.8 to 3.0 ppm per gallon. So two more.
Test at 9:30, FC is 20.5 and I do my first CC which is still 1, So I do three more.
Test at 11:45, FC is 25, CC is 1, FC is exactly what I predict it should be!
Test at 1:45, FC is 23.5, CC is 1. Add 1.
Test in morning for overnight test. Find small POSSUM IN THE SKIMMER, alive!!! Talk about organic material...
Fish him out by letting him cling to my vacuum hose, set him down, it promptly jumps back into the pool and starts swimming. So my first swimmer is a possum. I fish him out and he's let go into the tree line.
Test at 7:00, FC is 21.5, CC -1 . So a loss of 2ppm over 5 hours. Getting better, Add 1. Filter pressure is at 16. Water is VERY, VERY clear. That's over 25% on the filters...
Test at 11:45, FC is 20.5, CC - 1. Add 1.
Test at 3:15, FC is 21, CC is .5! Add 1.
So I'm going to backwash the filters, fish out some stuff I can clearly see on the bottom. Now, according to the guide, I keep shocking until I get an overnight drop of less then 1ppm. Correct?
It is safe swim at <10 ppm. Correct?
How much time usually passes between shock time and swim time?
When is it safe to test for other values? pH, TA, etc.
Thanks so much!
