What does that mean?Kir said:I already shocked
That depends if you followed the process. It appears that you have passed the CC and the OCLT (although this is usually done at shock level), and your water sounds clear (could you identify heads/tails on a coin in the deep end?)Kir said:So has the water been properly shocked?
Given this statement, it does not sound like you grasp the concept of the shock PROCESS yet ... there is no "shocking a second time". You are supposed to maintain the shock FC level continuously until all 3 criteria are met.Kir said:Should I shock the pool a second time just to be safe?
