13,000 gallon pool. I have 74% chlorine pro shock I'm about to use to do a triple shock today.
http://reviews.lesliespool.com/product- ... r-Pro.html
I have a Hayward E65 DE filter.
My pool place is telling me NOT TO RUN THE FITLER while shocking it because of how bad my algae is and that my de filter will keep clogging. Again, the algea is so bad, you can see the bottom anywhere. The pool is dark green/black. I have a loop lock cover and shocked it in april, bottom was clean, but I guess that wasn't enough.
I'm debating on what to do about running the fitler?? Again, my pool installer says I shouldn't run the de fitler while shocking because it will clog over and over because of how green/black the pool is. I don't know if I should listen to this, or run it and keep backwashing a bunch of times.
Advice? I really don't want to wait 2 weeks for this to clear up. Do I need to run the filter ever when it's this dirty? or triple shock it with it off, and then double shock the next day, etc. etc.?
Side note, one year I had bad algae and used this product and it seems to help super fast.
http://www.swimpool.com/GreenPoolAlgae-Green_Treat.htm
