Here is my solution to this problem. Start by acquiring a new "fuse"/"Roll out switch".
Take the front panel off of the unit. Clean the burner unit with compressed air and vacuum under and around the burner with a shop vac.....rinse and repeat if necessary. I use an air compressor to blow all the soot loose and then I vacuum all the particulate matter from the burner area.
Next, Leave the front panel off and start the heater. If you see flames "rolling out" toward the fuse, shut unit off and hit the burner with some more compressed air, and maybe a light brushing. Vacuum again, and start it up. You should be golden.
I would purchase back up fuses: https://www.poolsupplyunlimited.com...2100/84368p1?gclid=CKa9taWnmNQCFcxXDQodme8Ggw
and even cheaper: 005899F - Thermal Cut-off Fuse 106156 by Raypak
These are about $10.00 cheaper than Amazon.
Cheers,
Jeff
Cheers,
Jeff
