Just putting this out there for anyone interested! I know I wish I knew this when digging around for what pump....
Pump does go faster and slower, but these are a nice range i tested....watt draw based on the easy touch readings.
I have:
-1 drain, 2 skimmers (all 2" flex) ....~ 30', 25' & 45' runs
-2 returns (1.5" flex) and 3 step jets (1" flex) ....~30' 30', 40' runs
-2 laminars (1" flex) and 1 waterfall (1" flex) ......~20', 40', 30' runs
RPM........Watts.....
1300........125...low speed just to move water at times maybe when getting cold out
1350........140
1650........294...My normal speed
1700........320
1900........430...When I run laminars and board fall
2200........684....manual vacuum
2350........812
2600........1110
2750........1310
3050........1776
10hrs per day .07c/kwh is $6 a month!! Or is it double since its a 240v motor not ran on 120v
But hard to say as the flow charts show 0 flow at 20' of head, when I know there is a good amount of flow still...
Power of variable speed!!! I am pretty sure the IntelliFlo numbers would be the same
I have:
1350........140
1700........320
2350........812
2600........1110
2750........1310
3050........1776
