Ok first off this is my forth intex pool.
The new loops that the legs go through got my feathers ruffled. I assumed the legs would still go through the vinyl strap that goes around the liner and thats what the manual said also.
I did not need the filter that came with the pool so obviously I had no reason to read the filter manual.
After getting my pool filled and my sand pump running i stumbled upon an insert in the filter manual that says to put the legs on the outside of the big strap and through the smaller loop strap or whatever its called.
My question is, Should I drain and fix the legs or just leave it? the legs are not getting pulled in by the big strap so I would think it would be ok to leave it for the summer? IDK. I wish they put that insert in the pool manual not the filter manual
I also wonder if I could leave the pool full and do 1 leg at a time, but I dont think that would work because of the tension on the rope and then trying to get the leg back through the rope, if the pool hasnt collapsed by that point lol
The Wife and kids will not be happy if I got to drain, but if it has to be done it will.
