Regarding Intellichlor IC40: How much chlorine will this produce?
Specifically, any rough math to equate chlorine production time to FC rise.
I can set this IC40 to any percentage of pump run time, so I can then figure how many minutes/hours the SWG is producing. So, it makes a certain volume of chlorine per minute or hour?
Bottom line - What ppm FC rise per minute or hour of run time in 13,300 gal assuming clean, covered water?
