Thread: Too high Chlorine
    Mar 2008
    Garden State
    80
    Too high Chlorine
    Last Saturday I opened the pool and have been maintaining shock level or higher until all my algae was gone - used 48 gallons of 6% bleach. By Sunday the pool was clear, but there was some algae on the bottom which after brushing a few times per day for most of this week and maintaining the chlorine level has bascially been removed.
    My chlorine level is holding at a fairly constant 20ppm currently. Is it ok to just let it lower itself down over the next week or however long or should I try to lower it somehow?
    I have some of the tri-chlor pucks left from prior years, with a current CYA level of around 60-70 (haven't done a recent test after the water cleared up, probably will do a full test tonight) would it be best not to use these or am I ok using these in my old auto-chlorinator to use them up?
    Thanks!
    Pool Details:
    - inground vinyl liner, approx 35,000 gal; Hayward DE-6000; Pentair VS3050
    - 600sq ft Heliocol; Blue Diamond; 8 Gal Liquidator
    - TF-100
    Just let the chlorine level come down naturally.
    I would save the trichlor tablets for another time when your CYA level is lower.
    Mar 2008
    Garden State
    80
    Jason, thanks for the quick reply, that was my gut feel. Sounds like I should be investing in a liquidator.
    Pool Details:
    - TF-100
    Mar 2008
    Garden State
    80
    OK, ran a full test last night:
    FC: 0
    CC: 0
    TC: 20
    pH: 7.8
    TA: 100
    CYA: 70
    I think I am ok, though the pH should probably come down some. What movement (if any) should I see on that as the chlorine levels drop?
    Thanks!
    Pool Details:
    - TF-100
    There must be a typo, you can't have FC 0, CC 0, and TC 20. TC = FC + CC.
    You should see FC come down by 2 to 4 each sunny day. It usually won't fall overnight, but sunlight will bring it down.
    Mar 2008
    Garden State
    80
    Good catch, seems I missed the 2 on FC...it should be 20
    Pool Details:
    - TF-100
