Stabilizer after the winter
perryy
Active member
Aug 7, 2007
33
NC
Last year my stabilizer got way too high due to using stabilized tabs. Then I learned about you folks and switched to BBB. I had reduced the CYA to about 70 last year by replacing some water. I figured most of it would still be around now. But now it tests very low - there's not enough clouding in the test to make the dot disappear. So, I added the small amount of CYA i had in the garage and threw in a couple of stabilized tabs in the skimmer. i'll test again and see where I am. The Taylor booklet recommends putting CYA at 50 if planning to use unstabilized chlorine. Does this sound right?
