mas985 said:
pipes freezing solid will not usually cause damage. They need to have blockage on both ends in order for the pressure to build and bust the pipe. As pipes freeze, it freezes from the outside in so right before it freezes solid, the pressure is usually relieved through the non-frozen center portion. The only way to break the pipe is if both ends are blocked by either previously frozen water or by a closed valve.
I must disagree with Mark only because i have seen pipe(s) burst with no blockage on each side of the burst. While there is a void in the center of freezing water before it becomes solid, that void is filled with water and expands(hydraulically), and has no place to go, different than if it were a gas and could compress...
...I am concerned with the amount of failures Budman has experienced with his equipment. The filter cracked, the pump housing cracked, and now this. Something is going on with your equipment that may be related, or just a coincidence. But would make me concerned if not a little irritated.
