pwest
0
There are some tables at http://www.aquapoolstore.com/heaters/po ... PIPESIZING that suggest:
- your 1" gas pipe is the correct size as long as your run is less than 100'
- a 175k BTU heater should raise a 1,000 gallon spa 30 deg (F) in 107 mins (about 0.28 deg/min)
Your results (49 deg increase in 173 mins = 0.283 deg/min) are in line with this, so things may be as they should be if your spa is around 1k gallon.
-Phil
-Phil
