I'm at my wits end with this project. We started replacing our liner on Satruday...emptied the pool, cut the liner out, laid the new liner out in the sun...here it is Tuesday and we are still messing with it! We had problems getting it to stretch because it hasn't been the warmest here the past few days. Tomorrow it is going to hit 80 degrees. I am hoping we have more luck, but I am doubting it. Anyway, my questions:
1. We have the liner properly installed and connected to the walls. I put about 12-15 inches of water in it and have noticed that parts of the liner has started to slip and pull on the sides. What was 4" of overlap is now about 1". What can I do to stop this?
2. Should I be using a shop vac to help with the air? There are no creases just lots of air. It doesn't lay flat against the pool walls.
3. SHOULD it be laying flat against the pool walls? I have emailed the manufacturer because I am still convinced it is not big enough for our pool!! I don't want to keep filling it and have a seam failure or have a wall slip all the way in.
TIA!!
15ft 48" Above ground pool!
TIA!!
