THANKS! I have a question for you. How often do you vacuum your pools? Why do you vacuum them?
A little back info. about the question-You can see from my signature that we are new to this pool. I have been doing BBB from the very first drop of water in the pool. Every thing is going GREAT! I can/do pass the OCLT when ever I test for it (did it last night in face). BUT every day I see some brown/gray stuff on the bottom of the pool. Some days are more than others. It is never much but it is there. I really think it is dead algae as it is not grainy and is very easy to vacuum up.
Test results are from PM test after adding the evening chlorine
FC 7 (goes down to 4.5 during the day-full sun 10 hrs.)
CC 0
TA 90
CH? Vinyl pool so did not test
CYA 35
PH 7.4
We have little leaves/debris in the pool most days. Pump runs 10 hrs day.
So is my pool normal with having some "dead algae" every day?
Thank you SO much for reading this!
Kim
CC 0
TA 90
CYA 35
PH 7.4
Kim
