Thread: Safety Fence
    Safety Fence
    Looking for a rec on mesh safety fence... Willing to do it ourselves, but have no idea what to pay for it. If having it done is a bit more, well time is money and we would rather be swimming!! From what I have seen with online quotes it seems like it is only a few hundred $'s difference, but again dont know if I am doing them right.
    The pool is 35x15 rectangle, one side is grass. Would like one of the nicer gates. Thinking 4 feet tall, black.
    19.k gal Gunite SWG
    Dec 2007
    Central New York
    504
    Well........ my two cents.
    First, the new fence must be up to code for an inground pool. (here it is 4 foot)
    Second, you must have lockable gates.
    Go to Lowes and figure out what it will cost you for everything that you need. Then add 14 dollars per running foot to that total and you will have the approx. cost to have it done either by yourself of hire someone to do it. I would guess to go all the way around the pool will be $2200 to $2800, that's hiring someone. Doing it yourself about $800 to $1200. Usually, a color fence will cost you more.
    Cheaper way is to find someone that does it on the side and takes cash..... no receipt. Ask around and see if you can find somebody.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Then I must be doing good with a 1700$ quote from a place with bells and whistles...someone to hold accountable as well.
    19.k gal Gunite SWG
    Dec 2007
    Central New York
    504
    My daughter just had a chain link fence put in and the labor was 14 dollars a running foot plus the cost of the materials. To put in a solid fence was 19 dollars a running foot plus the cost of materials.
    Hotrod30
    Pentair VF3050 pump
