New pool owner here... many odd things I need to ask (Odd for me anyways).
1. Hayward H series pool heater... I start it up and after about 30 seconds I get a LO error... I checked the water pressure sensor and it constantly clicks... Could this be bad? And how would i know if I had a real low water pressure situation where the sensor would be working as designed? I was going to test the sensor by pulling the two wires and seeing if the circuit was open or closed with no power but looks like one of the leads may come out if I try to pull the wire off the sensor (unsure) so I left it. Might just replace it and see???
2. I have some bubbles coming out of my returns, usually I know this is a suction side leak, but I don't think so in this case.. the pump basket lid seal is good, the drain plugs seem fine, the unions seem OK... and no water drops near the pump... Now I do see where someone put in the chlorine feeder that they chose not to use unions, and I can rub my finger under the feed side of the chlorinator and I get some drops of water, plus if you move the canister a bit you can see the pipe rotate a tad (is this the problem?) if not all I can think of is to replace all the union seals and chk agn...
3. I have no power to my light, now how the heck do I figure out where it connects to? the pool has a large concrete patio surrounding it, I cant see where the line goes all I know is it has one coming out of the back of the light...
I do have more questions, and a lot to learn... not sure if anyone can help me... but I thought I would try.
Thanks, and God bless....
