I tested CH in my pool. When I put in R-0011L, the sample turns a little bit pink. However, I added about 30 drops of R-0012, there is no change in color (it remains clear with a little bit pink). Is it no CH or too much CH?
Per the instructions, after adding R-0011L, "if calcium hardness is present, the sample will turn red". In my case, the sample didn't turn red. It's just a bit pink (similar to 0.2 FC in chlorine test). As I said, I added 30 drops of R-0012 and the color didn't change. I thought it's no CH. I'm still adding calcium
Anything kind of red, like pink, counts as red. The exact color you see will vary depending on things like the FC level. If it turns blue right away, or anything similar to blue, then CH is zero.
I just went to Leslie's to have my water tested. The CH is low (<100). Is my test kit bad or their test is not good (they use test strip to test CH)? I'm using K-2006.
Try using 10 ml sample. 10 drops of R-0010, 5 drops R-0011, and then each drop of R-0012 is 25 ppm. The color should be deeper this way, easier to see the change. You'll probably be safe putting the first 5 drops in at once and swirl it for a minute, then swirl about that long for each additional drop. You're looking for sky blue, not purple. Something like this ?????
