Aqualink RS 8 Spa comes on in Pool Mode
May 19, 2012
19
I have a Jandy Aqualink RS 8, it is 11 years old. We had an electrician look at it the other day because one of the side outlet gfi's kept tripping at strange times. Then it tripped when we had the sytem in spa fill.
Then the Jandy Spa actuator valve was in the wrong position, even though it was still switched correctly to number 1.
BUT this morning I noticed the pool water level is down to almost the first tile.. AND the system is on filter pump, in pool mode and the spa is running!
I removed the panel on the PCB, took out the battery, and reset the board. Nothing...still does the same thing. :?:
I shut the main drain valves to the pool and spa.. I don't know why my water is down.
I appreciate all your help!! Thanks!!
