Yes, we are adding water from the hose (well water). I have never checked it's TA, will do that. Shocked at 20-21 ppm all day, water looks the same...
That would be unusual, are you adding any Muriatic Acid or dry acid (ph down) to the pool regularily?Jill said:As far as I know, my Ph never got above a 7.5. The TA of my hose water is 370
Are you running the pump the whole time?Jill said:If it's the filter or piping that could be leaking, why is it clear at night but cloudy come morning?
I am not sure you have mustard algae. Almost always it is found on the walls in an area that gets a lot of shade.Jill said:Keeping it above 25 is good? Or should I keep it above 30, figuring I have Mustar Algae?
