Hi All,
We have just ordered our first pool (18 X 40 AG)! It is to be delivered in about 2 weeks and then be installed shortly thereafter. The pump (dual speed), heater (100,000 btu propane), salt generator and sand filter will be about 10 feet from the pool and I am going to start with using the standard above ground plumbing that comes with the install. I will be hard plumbing and burying almost immediately since the pipes will be running in front of my crawl space door.
I am planning on using Schedule 20 2” PVC buried 12” to/from the pool. My question is about the run from the heater. Will there be any issue with running the PVC from the heater? I know that there are issues with running from household hot water heater with PVC since it could soften and cause leaks. I am not sure if the pool heater get’s hot enough to be a problem.
Thanks in advance.
Thanks in advance.
