Results 1 to 8 of 8
Thread: Jandy Valve problem
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    Jandy Valve problem
    The valve that turns when I go from pool to spa work ok when I'm in pool mode, but when I switch to spa it just turns in circles. I had the builder out yesterday and he told me there was water in the valve. How does that happen? Was I negligent or is this just something that's going to happen over time.
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    Mar 2008
    Maryland
    56
    I'm assuming you are speaking of the automatic turning jandy valves? I believe there are three small orings that will wear out over time. The replacements come together and are relatively easy to replace. However, there could also be a problem with the cam that stops the rotation in one direction. I'll check the Jandy service manuals just to be sure.
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    they're telling me now that it's a problem with the actuator - shouldn't you get more than two years from an actuator - especially one that isn't used very often?
    Brian
    Yes, you should absolutely get more than two years from an actuator. However you do need to perform routine maintenance. The problem might be as simple as a cam stop that fell out, even replacing the O-rings is fairly trivial. Most likely you just need some minor maintenance along those lines.
    My actuator has lasted five years, with maintenance (lubrication) about every other year. the owner's manual says to do it every year, but.... My actuator turns sometimes several times a day because it is used for the solar heater. It sounds to me like your has premature wear or an o-ring that gave out early.
    19,000 vinyl pool, solar heat, .75 hp tristar, 48 sq ft de filter
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    thanks for the replies. Is there any links to anything I can read up on routine maintenance for an actuator. I know I didn't get any kind of manuals for that.
    Brian
    Actuator manual
    Sorry it took so long, but here is a link to Hayward's page that has the owner's manual for a Goldline acuator. The maintenance is near the bottom, but there are descriptions of the cam and stuff if you want to try to troublshoot and repair the actuator yourself. http://haywardpool.net/inground/product ... D=128#five
    Chris
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    Re: Actuator manual
    Quote Originally Posted by ChrisL
    Chris
    you da man Chris!
    Brian
