Hello,
Here are first test results with the TF-100 test kit.
Ph = 8.2 (too high, correct?)
FC = couldn't do because I'm missing R-870 Powder.
T/A = 110
CH = 110*10 = 1100 (very high, right?)
CYA = <20 (like 10)
Pool water is looking a little cloudy and I can tell needs attention. We have a Safe-T 3 pool cover which is closed 90% of the time. This keeps the sunlight out and the temp at 80%. We moved into this house 3 weeks ago and pool was last serviced just before we moved in by their pool guy on 5/16.
Both Ph and T/A need to be lowered based on my reading and CYA should be increased. What do I do about the very high CH?
Thank you
T/A = 110
CYA = <20 (like 10)
Thank you
