Thread: Polaris 260 hose spraying the house.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    What are you guys using to weigh down the directional hose? Ours is always spraying outside the pool. My wife is getting sick of cleaning the windows all the time and the saltwater has started causing some rust around the trim of the back door. I know I read this somewhere before, but can't remember what people used.
    TIA.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    There's a sweep hose adjustment than will increase or decrease the sweep hose motion; that may help. Also check to make sure the foam scrubber is on the sweep and intact. Finally, Polaris sells a sweep hose weight you can use.
    SeanB's Avatar
    Mar 2007
    2,622
    Thanks Kurt. I'll try that out.
    TFP Founder
